Old Aug 18, 2011 | 01:38 PM
Chris2806126's Avatar
Chris2806126
Default Re: P0123 Throttle/Petal Position Sensor/Switch A Circuit High Input
Originally Posted by BadBoy007
Need your help! I visited Chrysler dealer!And recieved again following mistake! P0123!No mistake in transmission!
Whan I reach kick down point my car goes into save mode and check engine like come out.Only whan I reach kick down. Turn of and start my car and everything fine again till I reach kick down.
I change the whole pedal with two sensors but it does not helped me.
Realy need your recomendations!
Check on line, P0123 code is for the Throttle Position Sensor, not the Petal sensor. Might check the connections at the throtle body on the engine or the connectors in the computer area. could be the TPS on the throtle body itself also.
