Old Aug 23, 2011 | 04:04 PM
onehundred80
Default Re: window washer fluid sensor on when full
Originally Posted by gfolino
Hello, I just purchased an 05 crossfire which had a crack in the windows washer fluid reservoir. The sensor light was on as well due to no fluid in reservoir.. I replaced the reservoir and filled to the top (until overflowed) and the sensor light is still on? How do I correct the low fluid sensor light on my dashboard?
thank you!!!!
I have not looked at this at all and I am only suggesting it could be the sensor not working properly. Would it be possible to remove the sensor and test it?
Does it work on a float principle? If so it could be stuck.
