Old Aug 23, 2011 | 09:11 PM
loungn14's Avatar
loungn14
Default Re: Eurocharged SC Pulley results
Originally Posted by branimal
About how much would it be , if I had you do both a pulley and a tune with your guys labor ?
assuming going to the houston location? Its a pretty simple diy, and the tune is simple as well via eurotuner or cable
Originally Posted by Jason_HBC
waiting...waiting....
shouldn't be much longer my friend. We just test the wholly @#$% outta everything. We are waiting on a few prototypes to come back for inspection. Origional batch being made is for 50 units
Originally Posted by 32krazy!
jake the dyno #'s are impressive. can i guess thats over a stock car? have you dyno'd against a c3 to see if yours performs better? and finally when do i get my 63mm pulley!!
we have not, good idea tho! Oh and the 63 is next in line after this release!
Nice numbers and thanks for developing the pulley. I hope in the near future you guys go forward with producing a pulley that's equivalent to the larger crank pulleys.
I have a suspicion it can't be done due to belt slippage. Even with 90% belt wrap some pulleys will continue to slip since there simply just isn't enough friction between the pulley and belt.
Anyway, I hope this isn't the case.
correct, that is an issue, as well as heat/friction on the material or lack there of lol. A few of us have engineering backgrounds so if there is a way we will figure it out!
