Old Aug 25, 2011 | 03:46 PM
downwardspiral's Avatar
downwardspiral
Default Re: Will a Zex kit work??
Originally Posted by daithi2
Not to be a smart *** but if your selling AN fittings you should know AN threads are not the same at NPT. I don't know of many manufacturers that uses NPT on fuel system because they are less reliable at holding pressure then AN.
If you feel I'm still wrong then you gotta do whatcha do.
I never said it was NPT, it's obviously not a tapered pipe thread... I said I thought it was 1/4 flare (not inverted flare), which uses a 45º flare rather than a 37º like an AN would. The fitting in the picture I posted on the left is a 1/8" NPT to -4AN, the top of the fitting is -4.. the one on the right is 1/4 flare, which looks alot like an AN but the flare is not the same...
