Old Oct 13, 2005 | 10:12 AM
jjarocki's Avatar
jjarocki
Thumbs up Re: Question about body work ...
Just a comment on dry ice. You can usually find it in a big grocery store. I had a Nissan Titan and a small dent on the storage cover door. The metal was much thinner than what is on the Crossfire so I thought I would try dry ice. Bought $10 worth. Heated up the surface with a hair dryer to get it good and hot and tried the dry ice over and over again for 3 hours, cycling hot and cold.
Didn't even get close to removing the tiny dent.
Paintless dent repair is THE way to go. Find a reputable shop and keep their card, you will be happy with the result and you WILL have to go back from time to time. Don't forget to tip. It helps. I suggest an independent because they usually will work on one dent without charging you a ridiculous ante-in price per panel.
