Did more research, read the Service Manual. After realizing the "Floating Coolant Sensor" is actually the "Coolant Level Sensor", I decided to call up the Dealer to confirm, told them the sensor I needed should be mounted on the underside of the Coolant Resolver Bottle., asked if that was the Coolant Level Sensor just to confirm after reading the Service Manaul, they said yes after looking into it.
They wanted to charge $29 and some change plus tax for this sensor, I went ahead and did research online and found the site below for $15.95 plus $5.50 shipping, basically $21 bucks for the sensor but I also have a coupon code you can put in when you order, where they give you a 10 % discount on the entire order. Put the code
RPCART
So your order will be just under $20 bucks shipped for the sensor.
Here is the part directly to order if anyone needs for the future:
http://www.racepages.com/brand/hella...el_sensor.html
Comes with 12 Month / 12,000 mile warranty.
