Old Aug 27, 2011 | 05:53 AM
Valk
Default Re: Does this sound like a bad fuel pump?
The fuel pump has a "check valve" and the fuel filter has a "regulator"
if either of these are failing to work correctly this will cause the fuel in the fuel line to drain back from the engine fuel rail and cause the car to crank longer than usual.
Mine did this for a week and eventually the fuel pump failed.
I had a new fuel filter already.
