Old Aug 27, 2011 | 07:26 PM
onehundred80
Default Re: Alternator repair
Originally Posted by MikeR
180 is correct.... but not all tensioner assemblies have that 17mm hex on them....most will use an E-10 torx socket...it is NOT a security socket....
My factory tensioners have not had the 17mm hex on them but I did buy an aftermarket one that did....
That is strange as the repair manuals mention and show it specifically. There are many makes of non OEM replacements and everyone I saw had the boss. The cost of these arms varies from about $50 to $200+.
I suspect he 5mm lockng pin hole is in the slot that the stop runs in, although I have not bothered to look.
You do not want the wrench to slip when removing the belt and catch your fingers.
The how to post again; https://www.crossfireforum.org/forum...tml#post610912
This Torx is a tamper proof one, its a photo by James 1549/.
