Thread: Idler pulley
Old Aug 27, 2011 | 07:30 PM
onehundred80
Default Re: Idler pulley
Originally Posted by 32krazy!
because that is what the torx is for!! the nut is NOT for releasing tension but to hold the pulley on. use the right torx and it be ezpeazy, use the wrong torx and you will strip it
You had better read the repair manual and look at the photo in this post.
https://www.crossfireforum.org/forum/tsbs-how-articles/51409-serpentine-belt-replacement.html#post610912
That nut as you call it is cast on the arm.
That Torx screw holds the pulley on.
