Thread: Idler pulley
Old Aug 28, 2011 | 01:30 PM
onehundred80
Default Re: Idler pulley
Originally Posted by Gunny
Hi gang
Boy this is tight squeeze to get that Alternator out of the bracket, any tips how to rotate it.
Thanx....Gunny
The bolts go into bushings that get tight in the mounting brackets and hold tight against the alternator. These bushes have maybe made a slight impression in the alternator and just need to be loosened up.
The following is a post that had the same problem and managed to loosen the hold.
https://www.crossfireforum.org/forum...tml#post614646
I hope this helps, it is just held in by the tight fit once the bolts are out.
