Check Vacuum hoses for EGR valve
In the process of removing and cleaning my EGR valve (finally), I noticed one of the vacuum hoses to the solenoid assembly is exposed to a lot of heat and it seems to be degraded from the heat. So I just wanted to alert you all to that little issue. Also, I want to replace the hose and need to know what size it is and what it's made of.
Thanks
