Old Aug 29, 2011 | 07:36 AM
Franc Rauscher
Default Re: car loses power at high rpms
Originally Posted by buniqueXF
Heres the problem, when i accelerate the car any kind of spirited it will lose total power either in the upper rpms of second gear or right after i shift to third. Now let me be clear the car does not stall or die out.....it is still running, it is just idling and will not rev if i step on the gas..... if i turn the car off and back on it will continue to run fine until i rev it up hard again in second. Has anybody experienced anythng like this? It is very annoying and my neck is getting sore from the sudden power loss haha....oh its an 04 limited 6-speed
Assuming you are not hitting the rev limiter, I would agree with Valkryderguy.
Unless you have had it modified, the engine will cut out completely at 5740 RPMs.
roadster with a stick
