Old Aug 29, 2011 | 08:01 AM
32krazy!'s Avatar
32krazy!
Default Re: CHEAP Intercooler Pump & Better then the CM30
Originally Posted by kolevski
Hey Steve why do you think I'll need a resistor? I was just planning on soldiering the wires from the pump to the original harness. Didn't think I'd need a resistor but I may be wrong. Lucky I have you guys
John.
if you take the oem plug apart to reuse you will find a small resistor in place. i was told by the electronics shop that its used to absorb any voltage spike from the pump kicking on. mine was maybe 1$? i wanted to make the cm30 i was using to be close to stock as possible so i replaced it . you could prolly get away by not using a resistor
