Old Aug 30, 2011 | 02:26 PM
  #334 (permalink)
BoilerUpXFire
Default re: The Original & Official "Black C-R-O-S-S-F-I-R-E s" Rule Thread
Originally Posted by Erichenderson02
I guess it's more noticeable than I thought.
With my DCAI the grille is only held on by the two top bolts because I couldn't get my fingers under to lock the bottom tabs. You're saying you relocated them though? By cutting new ones?
The black makes it stick out more, it did on my last one.
I have rebent the grille slightly - to get more arc and set it back a little more for depth, shortened the tabs to accomodate the recessed grille, and bent them a little till I could use the mounting points.
On the bottom I used zip ties for a few months, tieing the bottom of the grill through the small 'lip' on the bumper cover at the rear, and over time, it ended up contouring the grille and bumper cover to look a lot better, I cut the zip ties weeks ago, but the change is permanent.
As I said, a lot of 'massaging'
Originally Posted by whereiswaldo
Do you have more information on this Tail of the Dragon weekend?
https://www.crossfireforum.org/forum...oct-1-2-a.html
There is the beginning of the 10 page thread, it has all the info you need. If you like fast, fun driving, the mountains, cars, good people, and some drinks in the evening, you will have the time of your life
