Originally Posted by El Steve
Someone in this thread indicated that the traction control is powered through the ABS fuse. Hence, no fuse = no draconian traction control.
Losing brake lights would be a concern, however. Need them.
YIKES: You guys are getting nutty... ETC can be completely disabled with The DRBIII... But, it works just fine on the track when you turn it off... It only starts applying brake pressure when you're F'd up in a turn... I've actually learned to like it in the OFF position... Except for the fact that it will take you down a couple of MPH when it kicks-in...
But I have disabled it completely with the scan tool...
