Thread: Major Problem
Old Sep 5, 2011 | 10:39 AM
oledoc2u
Default Re: Major Problem
Originally Posted by JimmySkullz
Then dont try it...Its doesnt do anything it wont hurt.. Maybe I got the description wrong but belive it or not sometimes it works.
Jimmy, you are right in your thinking, but the starter has to be engaged in order to turn the armiture. Shorting across will do this, but the starter is clicking, telling us that not enough cranking amps are present to spin the starter. Bad ground, bad connections, uncharged battery, and the list goes on. Usually start with the obvious, battery, then battery terminals, then, ground connections, then, connections to the starter, etc....etc....
