Old Sep 5, 2011 | 05:49 PM
JHM2K's Avatar
JHM2K
Default Re: Mercedes Engine Cover Mods and 74 mm Throttle Body
I'm going to be removing my intake tubes soon and switching over to the two plastic ones you showed us above.
The TVT tubes require band clamps to be used on the airbox side and on the silicone tubes passing through the core support... Anytime the motor shifts on the mounts, the band clamps pull crooked and no matter how many times I've straightened them out, they go back crooked after hard driving. No doubt, I need to be investigating motor mounts soon.
Also, the TVT tubes retain heat for a much longer time than the OE plastic. The plastic is very thin, so even though it does a poorer job of insulating from heat, it also sheds it faster. Finally, I've never been a huge fan of the fit on the driver's side... it always seemed a bit crowded.
Pics to follow
