Old Sep 7, 2011 | 12:57 PM
KelloggKid's Avatar
KelloggKid
Default Re: Custom Fit Near New Car Cover
Originally Posted by Kodebuster
What you will find at any Forum is that Problems tend to percolate to the top of most threads, and if think about every quirk and anomaly, your head will explode...
Overall if proper maintenance is applied, and a little common sense, or should I say, sports car common sense is applied, these cars are quite reliable.
Enjoy the ride, knowing there is a place like this to help you along if an issue surfaces...
Thanks for the kind comments. I'm no stranger to forums so understand what you are saying. I'm going through the inevitable "buyers remorse" phase which I'm sure will pass within minutes of actually taking possession of the car.
Once they get it detailed out, I assure myself that the rear window isn't going to fall out on the way home, and that the key actually turns in the ignition switch, put the top down, and get it out on the freeway, all concerns will quickly dissipate.
Thanks to this forum I already have a list of "to do's" ready to go
