Old Sep 8, 2011 | 01:33 AM
carlosshane1477's Avatar
carlosshane1477
Default Re: car loses power at high rpms
Originally Posted by buniqueXF
Heres the problem, when i accelerate the car any kind of spirited it will lose total power either in the upper rpms of second gear or right after i shift to third. Now let me be clear the car does not stall or die out.....it is still running, it is just idling and will not rev if i step on the gas..... if i turn the car off and back on it will continue to run fine until i rev it up hard again in second. Has anybody experienced anything like this? It is very annoying and my neck is getting sore from the sudden power loss haha....oh its an 04 limited 6-speed
Sounds like a clutch problem. When the clutch that transfers engine power to the means of transmission, so that he can no longer entrust this power example is the torque, it will really start to drag, which increases the motor speed and lose power to your wheels. The remedy is to replace the clutch. check out the list of tsb for more info about recalls and tsb's .
