My guess it's this one from the last site I gave you. Measure yours and compare, 1mm =.040". Second line down.
Door Panel Retaining Clip
Gray Nylon
Top Head Diameter: 13mm
Bottom Head Diameter: 16mm
Stem Diameter: 9mm
Stem Length: 13mm
Replaces Mercedes: 000-990-57-92
10 Per Package
Thats the site I previously linked in this thread that looked similar but did not fit correctly, those are too small. However, while browsing through the site I did manage to find some that did look identical, I will need to measure and confirm!
This is the ones that I found while browsing through the site:
Mercedes Trim Panel Retainer 11mm Stem Lgth
Its from the same website I ordered that you just mentioned, however, I was already told about previously from a fellow member on the site that mentioned it "should" fit but now I know they don't, hence my thread.
Going to contact the company on Monday and see if they would be willing to do an exchange of the ones that were the wrong clips that I ordered and replace them for the ones I just linked as that would be great if they could as I have no use for these that have been received. I will measure and report back. It would be sooo great if there the right ones finally!
