Old Sep 11, 2011 | 10:19 AM
onehundred80
Default Re: Ignition key is starting to lock up,
Originally Posted by doug5639
The car did not respond, it was as if the battery was dead, which it wasn't. I have had the ignition stick a few times and felt it may have been the cause. Once I pulled the key out of the ignition and reinserted it the car started just fine. It has me wondering it is the ignition or something else. I may fix and buy a newer Crossfire. This is a 2004 with 153,000 miles on it. It has been a great car.
It could be the CPS or even the ignition switch I guess. Fix the sticky switch and see if it happens again. If it restarted at once it could be the switch, it's hard to say with any certainty, maybe others will chime in.
