Re: Chrysler to Replace '05 Convertible Tops Under TSB - YAHOO!!
As some of you know, I work for BMW and I have access to ALL DATA and I looked up the TSB #23-035-11 thanks to rpb's post. I couldn't scan it but this is basically what it says:
Subject:
Convertible Soft Top Back Glass Loose And/Or Detached From Fabric (10 yr./100,000 Mile Warranty Extension)
Overview:
This bulletin involves inspecting the convertible soft top back glass and if necessary replacing the convertible top cover.
Model:
2005 (ZH) Crossfire Roadster
Note: This extended Warranty Bulletin applies to vehicles equipped with convertible soft top.
Symptom/Condition:
The customer may experience convertible soft top back glass loose and/or detached from fabric.
Diagnosis:
If the customer describes the symptom, perform the Repair Procedure.
Parts Required:
CNA6X310AA Convertible Top Cover
It goes on the show a picture of what the problem looks like and the repair procedure which is as follows:
1. Inspect the conv. soft top rear window for looseness and or detachment.
2. Is the rear glass loose and or detaching form the conv top?
a yes>>>Proceed to step 3
b No>>>Return the veh to customer this bulletin does not apply.
3. Replace the conv top cover. Refer to the detailed procedures avail in Dealer Connect......blah blah blah
4. Install the New conv top cover. Refer to the detailed procedures avail in Dealer Connect......blah blah blah
*****Important******
Note:Vehicles included in the Service Bulletin applies to the U.S. Market only and have a 10 year/100,000 mile coverage for this repair.
