Old Sep 14, 2011 | 02:33 PM
James1549
Default Re: Quick Oil Filter Questions
The last person that put your filter in, placed the oring improperly. Common problem I am seeing. I would suggest to replace the oring in question. However, you may be able to reuse it to get by until you get a new one, provided it did not tear it. See the red circle in the diagram below. Also be sure to lubricate the new installed oring with oring lube or clean engine oil.
