Old Sep 15, 2011 | 05:38 PM
NDguy23's Avatar
NDguy23
Default Re: Weird 2004 Crossfire Non Start Problem:
Originally Posted by onmark
Thanks to both of you I will check out the clutch pedal position switch. That is the only switch I find on the Clutch in the manual.
I had both problems as well, except I let the key problem go too long and ended up calling for a tow...I definitely recommend getting that fixed. As for the clutch pedal switch. You have to take two panels off to get to it, but it is easy to get to...just uncomfortable. Mine was actually loose, so I twisted it a bit and it worked fine. I still think mine needs replaced though, so if you find a place that sells them let me know.
