Old Sep 15, 2011 | 05:50 PM
Daniel454's Avatar
Daniel454
Default Re: Auto Headlights, Fogs On With Highbeams & Other Quirks Fixed!
Originally Posted by mjgroves
Pretty awesome mods sir. Reminds me of how I changed out my entire shift pod for an autostick one on my 2002 Stratus sedan...
One question... does the 2004 autodim mirror have the compass bearing in the upper right corner or did you add that? Where'd you go to find the instructions for doing so?
Thanks!
The Crossfire OEM 2004 Auto Dim mirorr has no compass in it. I am not sure of the exact thread but there was one or two on here that showed how to install it but again it doesnt have the compass. I used an aftermarket mirror, post with the link & model # is a couple posts up.
It comes with instructions but basically you just have to find a switched 12v supply which exists just in front of it on the Homelink / Garage door opener. You will have to also change out the mount for it if you go with te aftermarket one, which you wouldnt have to if you went with an original Crossfire model, but I wanted the compass.
