Re: corner bulbs
unless you have skinny and 10" long fingers, you have to remove the headlight assy. It's held in place by 3 screws, 2 on top and 1 below. For the one below, it's best to remove the wheel and remove 1 screw that holds the inner fender skin. Just peel it back and you will see the large adjusting nut with the screw you have to remove going thru it. Once the assy is out, twist the corner light socket out. I believe the bulb is 194 amber.
Hope this helps you... Turbomar
