Originally Posted by MAXIMUSQUO
Hi,
if you want use the transmission from Crossfire so isnīt a big deal. That what you need is an Mercedes DAS in development mode, switch your gearbox pcm in your C36 from manual to AT or otherwise and thatīs it,
regards V8Max
but my mercedes is in AT, also there is no direct way to buy a Mercedes ecu that is for manual, this is because the one currently in the trans connects with the ECU for the rest of the car.
Also, can the DAS allow me to retune it and trick the car into thinking that it is in NEUTRAL?
User Guide for Mercedes DAS Developer Mode Bluelans)
Also, I NEED a list of all the components of the manual system needed. I don't know where i could find an entire list of part numbers.
