This is a common issue that typically appears on the driver side, but is known to both engine sides.
If under Warranty, it should be covered.
If not, it's described as a relatively easy DIY fix.
Search the Form for Valve Cover for lots of links with lots of details.
You can start with this one:
https://www.crossfireforum.org/forum...-question.html
Here's a pix of what mine looked like with the oil leak.
Mine was under Warranty, so the Dealer did both sides:
