Old Sep 24, 2011 | 07:02 PM
  #66 (permalink)
onehundred80
Default Re: Valve cover leak...
Originally Posted by ri2300
On the lower gasket do you use rvt and a gasket?
Do i need to order this 2004-2008 Chrysler Crossfire Valve Cover Gasket - Victor Reinz W0133-1632508 - Passenger Side, Direct OE replacement
also what tools do i need?
what is the proper amount of torque? also what is a good torque wrench?
No RTV on the gasket.
Yes, that's the gasket for the passenger side.
Look at the bolts and screws and determine the sizes.
Torque wrench?, you could borrow one from someone surely. Tighten to 7 ft/lbs.
This looks good but for a one of use, it's not worth buying and too big for this job really.
https://www.crossfireforum.org/forum...h-special.html
You could get a cheaper one at a tool shop. A 3/8" square one would do for those bolts you are dealing with on the covers.
Download and save the Repair Manual from this site. There are many files worth saving here as well.
https://www.crossfireforum.org/forum...tml#post111722
