Old Sep 29, 2011 | 06:30 AM
onehundred80
Default Re: Skreem module installation ???
Originally Posted by ZORRO
I do not have picks. But what you do is remove the nuts then get a small gear puller to remove the wiper arms (yes on mine at least they are were on that tight) Then undo the torques/sp? bolts along the front of the panel under the wiper arms (just kind of pulls out of a gasket at the windshield) them right about the center of the firewall you will see what looks like a horn pointing up (cant mis it)
This is what I did to get the stupid thing to shut up. I just unplugged mine and never went back to replace it. Mine went bad three and a half states from home, figured if I replaced it I was just setting myself up for that again. Search under skreem and you may find a better description of how to do this. Have fun.
These instructions put you on the wrong side of the firewall, the SKREEM module is under the dash inside the car.
The instructions are in the Shop Manual, to be found here.
https://www.crossfireforum.org/forum...tml#post111722
