So today i finally got the time to take apart my dash to see what was actually wrong with the Ashtray. I figured there was some sort of spring in there that I would be able to remove and then just manually push/pull it.
Taking it apart is already explained pretty well in this thread I link below.
Only real probably i came across was that because i didn't have any real tools so i mostly used a small flat head screw driver. The only thing i did wrong was put slight marks in the #1 as i was torquing it off with my screw driver. Also, the numbers are not real clear on there, but you can figure it out pretty easy. Also not noted, there are 2 screws after you take the CD player out, but they're pretty noticeable.
https://www.crossfireforum.org/forum...in-holder.html
When you pull it out (if it's broken) it will probably look like this. That golden metal band is the spring which pushes the ash tray out.
The plastic cover in the picture is what broke off, and i found it underneath the ashtray. It is supposed to clip back ontop of the ash tray spring mechanism to help guide the locking mechanism.
This piece that i have circled is supposed to swivel into a position that allows it to catch when pushed all the way back. Then pushed again it unlocked.
Assembled it is supposed to look like it. If you play with it you can get the plastic piece to snap back into where it was supposed to be. Even with that piece back on I couldn't get it to catch so i decided to take the golden spring off and leave it as that.
With the spring out, you just have to push it in and pull it out. Doesn't seem like a big deal to me, and I don't have to worry about it failing on me anymore. There's also interesting peices of clear plastic a holder on the bottom of the Ashtray. If anyone takes this Ashtray apart and figures out what it's for im very intrigued, please let me know!
Also the last thing you will need once you reassmble everything.
Good Luck!
