Old Sep 30, 2011 | 06:46 AM
32krazy!'s Avatar
32krazy!
Default Re: Eurocharged Sc Pulley Ready 2 Order
Originally Posted by dinasrt
Please elaborate. According to EC's numbers on their website, the new SC pulley is approximately equal to the 181. According to them, the same torque claims for both. Doing the math on the new 64.7mm SC pulley, I came up with 18.7 p.s.i.g.
coutesy of brian brave. look at the s/c rpm #
By my calculations: (based on the stock 74mm S/C Pulley)
Stock Crank Pulley : 74mm S/C - - Ratio = 2.0270
Engine RPM @ 6,000 - - S/C RPM = 12,405
Engine RPM @ 6,200 - - S/C RPM = 12,819 - Rev Limiter W/Tune
Engine RPM @ 7,000 - - S/C RPM = 14,473
178mm Crank Pulley : 74mm S/C - - Ratio = 2.4054
Engine RPM @ 6,000 - - S/C RPM = 14,432
Engine RPM @ 6,200 - - S/C RPM = 14,914 - Rev Limiter W/Tune
Engine RPM @ 7,000 - - S/C RPM = 16,838
181mm Crank Pulley : 74mm S/C - - Ratio = 2.4459
Engine RPM @ 6,000 - - S/C RPM = 14,676
Engine RPM @ 6,200 - - S/C RPM = 15,165 - Rev Limiter W/Tune
Engine RPM @ 7,000 - - S/C RPM = 17,122
185 Crank Pulley : 74mm S/C - - Ratio = 2.5000
Engine RPM @ 6,000 - - S/C RPM = 15,000
Engine RPM @ 6,200 - - S/C RPM = 15,500 - Rev Limiter W/Tune
Engine RPM @ 7,000 - - S/C RPM = 17,500
Using a Stock Crank Pulley, the S/C pulley would need to be reduced to:
63.6mm to equal the boost of 178mm Crank Pulley running @ 6,200 Engine RPM
62.5mm to equal the boost of 181mm Crank Pulley running @ 6,200 Engine RPM
61.2mm to equal the boost of 185mm Crank Pulley running @ 6,200 Engine RPM
If 20,700 is the max S/C RPM; and to be safe we decide to stay 10% under max - that's a target of 18,630 S/C RPM - - (when at 6,200 engine RPM)
Stock Crank Pulley would need a 50.9mm S/C Pulley
178mm Crank Pulley would need a 59.2mm S/C Pulley
181mm Crank Pulley would need a 60.2mm S/C Pulley
185mm Crank Pulley would need a 61.6mm S/C Pulley
Check my numbers to see if I missed something.... because I want to replace my 74mm S/C pulley with a 61.6mm S/C pulley (16.78% smaller)
