Old Sep 30, 2011 | 06:32 PM
onehundred80
Default Re: Cold air intake with stock cover?
The intake tubes on the na engine cover are 2.75" diameter outside so you would need adapters to fit 3" inside diameter tubes. I cannot see too much improvement as the na cover is really restrictive. Look down the inlets at the filter area and then look at the Mercedes engine cover in use by many.
