Old Oct 4, 2011 | 05:38 AM
apkano's Avatar
apkano
Life is random...so am I.
Default Re: Garage Floor Options For Crossfire...
If you already have a dampness problem then I highly doubt a "stick-on" system will do much good.
I would either try using a sealant, much like Thompson's water seal, or do what I did, which is UCoatIt. It's an epoxy floor covering that's pretty much impervious to anything you'll likely find in a garage. Even brake fluid and battery acid won't touch this stuff. It can be a little pricey, but you'll never have to do it again.
UCoat It Epoxy Floor Coating
