Old Oct 4, 2011 | 12:09 PM
onehundred80
Default Re: Wire Routing/Access Question
Originally Posted by KelloggKid
Can anyone tell me how to route wire from the radio to the stock amp. I've got the amp out, have removed the radio and the panel under the passenger side dash but still can't find a clear path into the back of the console to the radio.
What added panels do I need to remove to snake a wire to the radio?
I added a CD unit in the trunk and access was easy for the wire running from the radio to the trunk. This photo shows a panel removed and the thicker wire on the left comes from the radio and it then passes over the amp unit.
Here's the panel and as you say later on below it is just clipped in and held with one screw.
