Originally Posted by killerkanadian
Your hoses connect to blocky plastic parts next to your radiator. You have to pop those out. Once you do that you can run 3" hose through the passanger side and 2-3/4" hose through the driver side. After you get the hose through you'll just get 90 degree couplers and install filters.
you said that the driver side whole throught the raditor is 2-3/4" and the passenger is 3". Are you sure there different sizes? They look the same andi just wanted to run a 3" 90 degree bend, I can do that right, or do I need reducers?
