Re: Bas/esp?
you can put the car in the on/run position, then, crank the wheel all the way to the right stop, then all the way to the left stop, then back to center... This should reset it...but there is a sensor, that could be going bad as well. The Angle Sensor, or something like that...James may be correct as well. The car is sensitive to voltage spikes...
