Re: Cold air intake with stock cover?
Originally Posted by Pat13
Yea before i even started this thread i looked behind the grill. so it is possible to go 3' all the way around? if not i was just going to do the 2.75' but if you can fit it i will go with the 3". I was going to order everything today but that one comment made me have second guesses. I am going to run that mendrel double bent pipe that resembles our stock plastic tube, then a coupler to a 90 degree silicon bend, then to the filter. Does that sound right?
For the price of the dubious Devils Horns, in my mind anyway, you could buy the Mercedes engine cover, fit the larger 3" tubes, larger K&N's and be ahead of the game for the same money. The Merc air box flows better no matter what you put in front of the OEM box.
Then the larger MAF, throttle body and tune and you can keep up with JHM2K. Maybe.
