Old Oct 5, 2011 | 06:27 AM
onehundred80
Default Re: Lowering my water temperatures
Originally Posted by waldig
FYI your car is throwing off about 75% of the power as heat to the 25% actually that goes to the rear wheels. I.E. 400HP @ flywheel and then sent to the rear tires (bout 350) means your burning way over 1000 HP worth of additional heat producing gasoline, to produce this power. A horse power is equivalent to 746 watts or about 2100 btus, so the radiator is getting rid of over 1-2 million btus per hour. Phew
Your home gas furnace has between 60,000 to 100,000 btus output for a comparison. Heat pump? well most of them are between 24,000 and 48,000 btus for a regular home.
Woody
I always heard that less than 20% of the power in fuel was usable in the internal combustion engine and available at the flywheel and even that depended on the engine efficiency.
Also the faster you go the more you waste due to aerodynamics.
Buy ten gallons and throw away eight at least.
We just have to do better somehow.
