Originally Posted by CaptDave
...........I went in to the menu of the 901 and turned off the internal amp since it is not being used....
Because the Kenwood menus change depending on the source, I never would have known that you could turn off the internal amp if you hadn't mentioned it. You got my curiosity up so I checked the manual and sure enough, there it is under Initial Settings. Thanks.
