Old Oct 9, 2011 | 11:18 AM
XFireCrazy's Avatar
XFireCrazy
Default Re: Need to run wires from license plate to inside of cabin with no drilling
Originally Posted by Erichenderson02
If you remove the diffuser (only tried on the passenger side), there is a drain plug that you can pop out and you can run wires through the hole into the trunk cargo area.
Ok, I looked up what a diffuser was online, but I stil am not sure what part on our car you are referring to. lol I am going to be routing some wires for my backup camera today. Thx
Wiki Definition:
A diffuser, in an automotive context, is a shaped section of the car underbody which improves the car's aerodynamic properties by enhancing the transition between the high-velocity airflow underneath the car and the much slower freestream airflow of the ambient atmosphere. It works by providing a space for the underbody airflow to decelerate and expand so that it does not cause excessive flow separation and drag, by providing a degree of "wake infill". The diffuser itself accelerates the flow in front of it, which helps generate downforce.
