Old Oct 9, 2011 | 07:05 PM
XFireCrazy's Avatar
XFireCrazy
Default Re: Kenwood KIV 901BT Installed yesterday 9/11/11
Originally Posted by CaptDave
Sound... Fantastic. Gone are the rattles in the doors. Clean sound with back pumping lows from the subwoofers that have never sounded so good. I went the RCA pre-out connections. Fronts wired to the original wiring using the RCA connections and wired to the adaptor connection plug. Subwoofers are wired to the RCA Sub pre-outs by running the connection all the way down to the Factory Amp and clipping wires 10,9,8,3 and connecting there... that worked wonderfully.
You mention that you attached your Sub Pre Outs from the HU unit to pins 10,9,8,3 on the Amp. Do you not have the Infinity sound system? Perhaps this is why I am so confused by your directions. I thought all of these stock stereos had the same Amp. Or perhaps there is a difference between your year and my 05' Roadster.
Here is what I found that the pinouts should be for my Amp. Obviously 10,9,8,3 is not gonna work for me.
