Thread: Limp Mode
Old Oct 12, 2011 | 08:12 AM
DTMenace's Avatar
DTMenace
Default Re: Limp Mode
Originally Posted by rg44
Hi guys. Long time lurker, first time poster.
I've owned my SRT6 for about a year now, and it's started dropping into limp mode when it gets warm. After searching the forum I came to the conclusion that it was the intercooler pump, but I took it to the dealer anyway since it was still under warranty. They ran a port diagnostic and apparently found some EGR codes. So they investigated the EGR system (including removing the supercharger), but found no issue. They've decided it needs a new ECU, which isn't covered under warranty. Because the fault (the one they've decided on) isn't covered by the warranty, neither is their diagnostic charges. So, I'm looking at £600 for them to put the car back together and £1800+ for a new ECU.
So... there's the story... now here are the questions. Do you think it's really an ECU issue, or something else? Could the pump failing cause an EGR code? If it's the pump, what can I do to prove it?
Any help you could give would be greatly appreciated
rg44
The attached page contains numerous threads concerning the pump failure issue, this is not an ECU issue. You should print the various threads and present it to the dealer, as proof that its a pump failure. When it goes into a limp mode, it is protecting the supercharger from a failure of overheating. Failures usually happen during warm/hot weather.
Good luck with the dealer....
Dennis
https://www.crossfireforum.org/forum...archid=1452373
