Originally Posted by frankeyser
I really thought for the best eurocharged tune you had to have the upgraded injectors or you would run lean. If that is not true i wonder where i got the idea.
You were probably reading the same post(s) I was when I was given the injectors. If I remember correctly there was some discussion of benefit of larger injectors when paired with a tune. True? Not sure but I did notice a mpg pick-up. Not a lot but it's there.
