If you have it, I would use the V8 MAF in the 74mm housing. Here's why: It is a MASS AIR FLOW METER. It works by keeing an electrode at a contant temperature. More air cooling it requires more current to heat it. The sensor is also calibrated to the diameter of the housing. A larger housing means more air (MASS AIR) is passing through. Is this starting to make sense?? No need for a tune. Our cars run a open loop fuel management system and can adjust to differences. Just an FYI, when I got my V8 running, my V8 MAF was bad so I put the V6 one into the V8 housing and ran that until the new one arrived. It seemed to drive just fine.
