Thread: Major Problem
Old Oct 13, 2011 | 07:00 PM
onehundred80
Default Re: Major Problem
Originally Posted by ShaunXFire
Everything I've installed Ive unhooked. HIDs, Subs and amp. I just had the alternator rebuilt 700 miles ago. It takes about a week to drain a fully charged brand new battery.
I can't find any lights on at all anywhere.
You could take out the fuses and connect a voltmeter between each terminal and see if you get a reading. No reading would show that those components are not draining the battery.
Connecting the voltmeter between the disconnected battery cable and the battery should show the drain, if not the drain is in the battery or it is an intermittent drain.
