Thread: Major Problem
Old Oct 13, 2011 | 08:51 PM
onehundred80
Default Re: Major Problem
Originally Posted by The Beep
You could use the DC voltmeter at the fuse box by pulling each fuse. At the battery it's self, disconnect the pos terminal and use the amp function between the cable and post to check for current flow with the car off.
Good luck.
Yeah that's what I meant, I used voltmeter not multi-meter, there is a standard drain anyway you just have to know what that is and see the difference. What is the standard drain? It is on the forum somewhere.
