I think you are confusing the pin numbers of the connectors.
Try this post...should help you out.
https://www.crossfireforum.org/forum...p-diagram.html
I was a little confused about the pin numbers myself, but once I saw the amp it was easy to figure out the pin numbers by using the color of the wires, as noted in the diagram from the post above
