Old Oct 15, 2011 | 12:07 PM
XFireCrazy's Avatar
XFireCrazy
Default Re: Kenwood KIV 901BT Installed yesterday 9/11/11
Originally Posted by 05-crsfire
I think you are confusing the pin numbers of the connectors.
Try this post...should help you out.
https://www.crossfireforum.org/forum...p-diagram.html
I was a little confused about the pin numbers myself, but once I saw the amp it was easy to figure out the pin numbers by using the color of the wires, as noted in the diagram from the post above
Yes, I was completely confused about the pin numbers. The information that Crutchfield had sent me was incorrect. Then I found some other info in the forums that had a different set of pin numbers and those were also incorrect. lol Finally, I was able to read enough posts to figure out that pins 3 & 8 were actually the rear left speaker and pins 9 & 10 were the rear right speaker even though the other two diagrams did not show this.
I now have the HU installed with the bluetooth, rearview camera and with the Subs working. The volume still does not crank very high, but I have amazing bass now compared to before.
Thanks for everyone's help. I was hoping to go back over the entire process with a video camera to help future installers, but I had to get the car put back together to take it in to get my new soft-top installed by my dealer.
