Old Oct 17, 2011 | 04:11 PM
waldig's Avatar
waldig
Talking Re: Correcting negative camfer
NEGATIVE< Its camber.
Camfer: Chamfer
From Wikipedia, the free encyclopedia
A chamfer is a beveled edge connecting two surfaces. If the surfaces are at right angles, the chamfer will typically be symmetrical at 45 degrees. A fillet is the rounding off of an interior corner. A rounding of an exterior corner is called a "round"[1] or a "radius".
itations to reliable sources. Unsourced material may be challenged and removed. (May 2009)"Chamfer" is a term commonly used in industrial engineering. Special tools such as chamfer mills and chamfer planes are available. In tile work, or furniture such as counters or table tops, an edge or arris that has been eased by rounding instead of chamfering is called a bullnose. Where a chamfer does not go to the end of the piece, but "lifts out" in a smooth curve, the end is called a lark's tongue.
An example of chamfering is part of the process of hand-crafting a parabolic glass telescope mirror. Before the surface of the disc can be ground, the edges must first be chamfered to prevent chipping. This can be accomplished by placing the disc in a metal bowl containing silicon carbide and rotating the disc with a rocking motion. The grit will thus wear off the sharp edge of the glass.
Woody
